Hey guys, here's some pics and video from my install of this same starter. Prior to ordering the starter I PM'd JerseyJeep to see if he was still happy with his and he was. My last starter (NOS) was a lemon, it had signs of water damage and I replaced the solenoid last summer. This time it was the main drive that went. While troubleshooting the old starter I found the ground cable casing was melting, so I replaced both the ground and battery cables just prior to this installation.
The SAASE company rep on the phone said he had sold a few of these starters for these trucks and that drilling 1/2" holes to 5/8" would not void the 2 year warranty. It was just $15 to ship it to a business address. They sent me the model with the TCS switch (over crank protection) at no extra charge because they were out of the U392412VB starters but should have more soon.
The starter that arrived was made by UniPoint, a Taiwanese manufacturer. It appears to be a clone of the Delco 39MT starter and supposedly is as reliable in independent tests. I can't find the PDF I read to share but they're tested to 22,000 cycles or something like that and a very close match to the Delco model in all respects.
My truck didn't come with a relay originally so all I had to hook up was the starter button wire, battery cable, and ground.
There may be more room but there's zero room for getting a socket around the mounting bolts, you're kind of stuck using a open ended wrench to tighten those 15/16" bolts.
Note, I adjusted the mounting flange (6 bolts) so the drain hole was pretty close to the 6 o'clock position. However, there is no threaded hole for the adjusting bolts in the high noon position. I spoke to the tech at SAASE and they said that's not uncommon and it was OK to use just 5 bolts to hold the mounting flange at this position. Note, the flange doesn't quite match up to shim on one side, I've enclosed a picture of this under-bite, but I think that's minor. I used black RTV on hand for the gasket.
The position of the relay was easy to adjust, just loosen the bolts and slide the band. I did this to move the relay away from the heat of the flexible exhaust pipe.
Here's a video of mine starting. I spun it twice without fuel and gave it juice on the third spin. My first impressions are its a little softer and gentler then my old surplus military starters, not what I was going for but for the price, newness, reliability, and warranty I'm not going to complain.
[media]http://www.youtube.com/watch?v=v0dX-2zzCos[/media]
