Keith_J
- 1,318
- Schertz TX
Yes, it happened. That is why I had the starter hang-on. This time, it caused a little overheating of the starter, took me 45 seconds to pull batteries. But the heat was from friction, not resistance so the windings in the field and rotor look fine. Just a bit of steel wear, not an issue.
Bushings and brushes are fine. Just need to weld the nose cone back on to the base, true up the bushing bore and reset the nose bushing.
Even took the solenoid apart, no real wear or weld points.
