2014 VIN Info Thread
RustyM923
California
1989 BMY M925A2
a. Serial Number (VIN number) 1002AA097
b. Registration Number -----None noted
c. NSN without dashes -----2320012300308
d. Where you bought it - Fontana, Ca (Govliq)
e. Bumper numbers - 79 / 40 THBS (possibly "THBSB")
Rusty Nut
Chicagoish, Ill
1991 BMY M923A2
a. Serial Number (VIN number) 2306404
c. NSN without dashes -----2320012300307
d. Where you bought it - Sparta,Wi
e. Bumper numbers - (Left)100QM / 88RRC (Right) WQ4WAAD0002/QM131
Thanks You: Carnac the Magnificent
1 Patriot-of-many
79
Zimmerman MN
I have two for you sir, wrecker and tractor which has 3 different serial plates:
Serial 1032AA026
Reg# NL0TUX
NSN 2320-01-230-0304
Bought Camp Ripley Little Falls, MN
No bumper numbers legible on this 1991 BMY M936A2 wrecker truck
There are actually three serial plates on this 1990? BMY M931A2? M932A2 tractor truck! Vehicle has everything but bumper extensions and the front winch, has the PTO takeoff and controls for the front winch.
Serial 3100133 or 3200133 or 3300133 Black plastic plate, stamped plate, PMP plate. Stamped plate and rebuild plate both have same date RRAD 06-04 along with all but one MWO on the drivers jamb having the same date. One other MWO on the jamb has 2010 date.
Reg# NL0XW2
NSN 2320-01-230-0302 or 2320-01-230-0303 Depending on M931A2 or M932A2
Bought Fort McCoy Sparta, WI
Bumper markings legible 758MT(right front bumper) W(right rear frame)
Thank you!
RecMech
New Hampshire
Organization: HHD, 867TH QUARTERMASTER BATTALION
Nomenclature:TRUCK CARGO 5-TON Model:M54 NSN:2320008358348
Serial Number:674 Registration Number:5159866 Year of Mfg:1952
Manufacturer:31007
Info Dec 1981
Much older than I thought! Thanks so much.. Just made my donation.
Bijou
New Orleans, LA
Carnac, Thanks for the help on this one.
M931 Truck, tractor, 5-ton, 6 × 6, w/o winch, soft top, ABS
Serial No: C53102830
NSN 2320012064077 Truck, Tractor: M931A1 - This NSN was on a sticker on the bumper
but this number looks like it should have a winch and closed top
NSN from downloaded Manual - 2320-01-047-8753 TRK TRAC M931
Purchased: GL auction at Camp Shelby, MS 4/14
Bumper Numbers
1387 408 (front left bumper)
MS184 298 (front left bumper)
Part NO 8750159
Truck No. 1387 408 (front left bumper)
Truck No MS184 298 (front left bumper)
Bijou
New Orleans, LA
After running some graffiti remover over the spray painted bumper numbers I found another number hiding under the top number. SB115 or SD115 on the drivers side.
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Reo M35 located in uk
Vin No 013010607
Reg No 608 UXJ
NSN No 2320008358515
Brought in uk
No bumper markins
None of these numbers are in the database. From the looks of it, nothing even close to the numbers you listed are in the system therefore I think you are using the wrong numbers. Might want to validate the numbers from the frame rails. Some of these trucks would have it on the right hand side and beginning with an M.
CARNAC
619
Corpus Christi, TX
1989 BMY M925A2
Organization: COMPANY G 40TH SUPPORT BATTALION
Nomenclature:TRUCK CARGO D/S 5-TON Model:M925A2 NSN:2320012300308
Serial Number:1002AA097 Registration Number:NL0SG2 Year of Mfg:1989
Manufacturer:47457 Contract Number:DAAE07-86-C-J111
Info Mar 2012
CARNAC
619
Corpus Christi, TX
Bumper Numbers
Part NO 8750159
Organization: 6ADA PATRIOT TRAINING, HHB
Nomenclature:TRUCK TRACTOR 5-TON Model:M931A1 NSN:2320012064077
Serial Number:C53102830 Registration Number:NL0MHV Year of Mfg:1985
Manufacturer:65909 Contract Number:DAAE07-81-C-5597
Info Oct 1996
CARNAC
619
Corpus Christi, TX
Serial 1032AA026
Reg# NL0TUX
Reg# NL0XW2
Thank you!
Organization: 1ST BATTALION 77TH ARMORED RGT HHC
Nomenclature:TRUCK TRACTOR 5-TON Model:M932A2 W/W NSN:2320012300303
Serial Number:3200133 Registration Number:NL0XW2 Year of Mfg:1991
Info Oct 1993
Organization: 1135TH SUPPORT COMPANY Location: ARDEN HILLS, MN
Nomenclature:TRUCK WRECKER 5-TON Model:M936A2 W/W NSN:2320012300304
Serial Number:1032AA026 Registration Number:NL0TUX Year of Mfg:1989
Info Feb 2013
CARNAC
619
Corpus Christi, TX
1991 BMY M923A2
Organization: 1008TH QUARTERMASTER COMPANY Location: GRANITE CITY, IL
Nomenclature:TRUCK CARGO D/S 5-TON Model:M923A2 NSN:2320012300307
Serial Number:2306404 Registration Number:NL117U Year of Mfg:1991
Info Sep 2005
MajorUSAR
Birmingham/AL
Info for my 1985 CUCV Blazer
a. 1G8ED18JXFF102886
b. NF074L
c. 2320011232665
d. Private sale from owner in Auburn, Alabama. He bought from GL.
e. Left = 1-AE/157INF Right = 1/349 28
Bijou
New Orleans, LA
Carnac, do you know if anyone (database) keeps records of what work was done to a "Refurbished" vehicle? My M931 A1 was supposedly refurbished in 2010 but I have no way of telling what was done to the truck. Thanks again for the wonderful insight into these vehicles.
CARNAC
619
Corpus Christi, TX
No. There would be a generalized statement of work as part of the contracting for the refurb but it probably wouldn't really help you with exact specifics for your specific truck.
fuzzytoaster
3,028
Fort Worth, Texas
M51A2 W/W (dump) w/ LDS465
a. 512312382
b. None
c. 23200559263
d. Local Municipality
e. None
Overhaul tag USA-MP BOEBLINGEN - MAR 73
Helidude
North Dakota
M923A2 Cargo Truck
A. 2302703NL0UEV
B. Unable to locate.
C. 2320012300307
D. Camp Grafton, Devils Lake ND.
E. 3662MC (right side) M082 ( left side)
Delivery Date Feb 12.
Helidude
North Dakota
M936A2 W/W Wrecker Truck
A. 36700497NL0BYW.
C. 2320012300304
E. D1-188ADA (right side) D3-123 (left side)
Delivery Date blank.
Dozer11B
Alabama
1984 M1009 CUCV
a. 1G8ED18J5EF123949
b. NFO2SD
c. 2320011232665
d. FT Hood area.
e. HQ 820 stenciled inside doors.
Thanks for what you're doing Carnac!
fuzzytoaster
3,028
Fort Worth, Texas
Pile it on. I'd like to do one large batch later this week than a bunch of one here or two there.
Well in that case.. :grd:
1984 M1028 CUCV
a. 1GCHD34J9EF360383
b. N/A
c. 2320011275077
d. FT Hood
e. Dash Sticker: USAOTC Test Support Contractor 035193
