Anyone know the proper way to adjust/check the throttle valve cable on these trans? I'm fixing to install the updated throttle linkage and wanted to install it properly while I had it apart.
On a side note, what does your trans temp normally read when the trucks up to operating temp? Mine moves when the truck is turned on but not after that, stays 100-150. So I'm wondering if it's really running that cold, or the sender's shot......
Thanks! I couldn't find a mention of any of this in the manual.
