BBQROD
- -13
- 0
- Gray Georgia
I have installed a new clutch and four finger pressure plate and after about 1:30 min of driving 50 mph with no load she'll start to slip on long hills. I'm stumped.
Did you resurface the flywheel also?I installed a new rear main seal. And no visible transmission leaks were visible and yes the pressure plate was resurfaced
Is transmission oil overfull it there have been several threads on not overfilling .Ah I found 90w oil coming out of the trans input shaft seal today! (Here's your sign)....
there is no front seal. all front leaks are almost always traced back to bad front bearing and damaged or loose or no gasket front bearing retainer. if it leaks with proper oil level, bottom of fill hole, there is something wrong at front bearing.I will check but it was noisy when clutch is out (in-gauged) in neutral
