- 14,639
- 4,815
- Buchanan, GA
Yeah I've thought about dragging the M55 or M543 around, but stopping it is the part I'm worried about.Tow your wrecker around with it.
You sound like me or vice versa. I don't baby mine, now I don't abuse it but baby it. NO.they hate lugging in 5th, they like to be run at normal operating temp, and mostly above 2K on the tach. Many on here stress that multi's want to be babied but that's just not their nature. I've read the threads about blowing holes in the block from 1 or 2 of about a million trucks. I run mine at 2650 rpm's in 5th all the time for long stretches at a time, I used to baby it and it led to hard starting, rough idling, alot of snot out of the slobber tube and general irritability on the trucks part. I now run it like the Army still owns it, and he loves it.
This was from a few years back. I ended up locating the crack on one of the cyl jackets. Repaired all of it, put a cyl kit in it, drove it for a while. Ended up cracking a head or something else. It's sitting in my junk pile now.Question... what is the current status of this engine? (respectfully)
I am having very similar conditions, oil cooler and a head has been replaced, and still loosing coolant to oil pan...
Debating investing the time/money to this engine vs engine swap.
Now what is going on? I thought you were good to go after changing the radiator cap?Question... what is the current status of this engine? (respectfully)
well, its not spraying water out from the cap, but it still going SOMEWHERE... and I have foamy crap from the slobber tube, and the oil is turning green and HIGH up on the stick... (I've put about 6 gallons of coolant, mostly just water, through it), so I wont run it like that, its parked until I figure out what it is.Now what is going on? I thought you were good to go after changing the radiator cap?
How long has it sat with water and antifreeze in the oil?
