- 4,640
- 28
- 38
- Cambridge, Ohio
The solenoid will retract and stay retracted for as long as the master switch is held in the "start" position. It will also stay retracted in either of the "Prime & run" positions only as long as you have oil pressure and are not overheating. The instant you turn the master switch to "off", the solenoid is supposed to drop out because you have cut the power to it, then it doesn't care what the safety switches do. It has no power so even if you still have oil pressure for a few seconds, the solenoid will drop out.Maybe its just my headache or the fact the 002/003 market is drying up in the south so I havent touched one in a few months, but does the solenoid not retract/stay retracted while in the run position for a few seconds if the switches are good? If you have good oil pressure and its not overheating, mine have all stayed retracted for a moment until the oil pressure sensor opens at its preset.
