LMTV numbers for filters
73m819
325
gainesville, ga.
There is THREE filters in the engine compartment, here is the WIX numbers that they cross to.
1 --- Fuel ------------- WIX 33755, had a nsn number filter, no name of maker
2 --- Small canister -- WIX 33239, had a Baldwin BF984
3 --- Large canister -- WIX 51791, had a Fram PH49A
Hope this helps
jtron79
Eugene, Or
Thanks for posting the numbers Ron I meant to do it after I picked a couple up. On the first number the 5 should be removed. Wix 33755. If you haven't used fleet filter to purchase filters it's highly recommended. Napa runs around $50 for this one and ff is $22. There is also an xe version available for the oil filter you listed.
73m819
325
gainesville, ga.
1 --- Fuel ------------- WIX 533755, had a nsn number filter, no name of maker
Hope this helps
By any chance have you run into any LMTV Light Materials Crane Parts?
NO
Yep I see that I fat fingered the 5, since I CAN NOT edit the first post, I hope members read down the thread,
1,132
:) Fixed
