Before I sell my M1009 (Injector pump)
I_Publius
Prosper, TX
More and more my IP is giving me troubles. I have to keep bottles of water in the truck and pour over the IP each time, if I turn the engine off, when warm, for more than 30 mins.
Although I love the truck, I can't keep worrying about this truck leaving me stranded and I also don't want to keep pouring $$ into a truck that won't go over 55-65 mph.....
Any suggestions about work arounds for the overheating IP issue? I just looked the part up on line with NAPA and they want $700+ for a re-mfg IP. Uggg!!!!
Maybe just pull the engine and put a 4BT or something similar?
Sorry to rant...I know this has been covered a million times...but I thought I'd check and see if I missed anything in the notes.
thanks, from North Texas.
Sharecropper
987
Paris KY
Hey - I am not a mechanic, but I pulled my IP off and sent it out for rebuild, and then re-installed the rebuilt unit myself. It wasn't easy, but I wrote down every step I took and then installed the rebuilt pump in reverse order. After it was over and done, I kinda enjoyed the whole process. There are plenty of threads on SS about how to do it properly. Don't give up on your truck because of a simple fix.
I_Publius
Prosper, TX
Thanks to all.....
I'll take a breath and rethink through everything tomorrow! :)
I like the idea of rebuilding it myself...may have to consider that.
I'll reach out to K9Vic tomorrow, as well.
thanks again....
lostintexas
Houston, TX
Good luck with the IP. There is a place I remember a thread on around Houston that was suggested by a couple of users here. Seems like price was ~$300 for the rebuild. Hang in there and shoot me a PM if you ever decide to sell :)
Publius, Theres a company on fleabay that will rebuilt ur pump for 255 out of Tennessee that includes shipping both ways. Ive had 2 done and very happy. Even had them turnup pump 10% for the military trucks. Pm me if you need contact info.
Recovry4x4
LLM/Member 785
1,808
GA Mountains
For a few hundred dollars and a few hours of quality time with your truck, you can alleviate all the problems and cruise at 70 again. While I like 4BT swaps, you have an easy fix on your hands vs re-engineering a truck.
I_Publius
Prosper, TX
Sweet. That could seal the deal, right there. Although I would love to switch out and put in a 4BT, I would rather just stick with this one until it's completely dead.
M1009 NEWBEE 2013
Colorado
I cruise with no problems at 70-75mph in my 09 daily (when I do drive it). It purrs like a well oiled sewing machine. You should have no problems getting to those speeds with a properly running truck.
M1009 NEWBEE 2013
Colorado
Don't give up on her, they are really great vehicles, once you get the kinks worked out; get your IP rebuilt and youll be surprised at how well it drives on the highway or at speed. Have you verified you have original gearing in the rear at 3:08?
M1009 NEWBEE 2013
Colorado
If it is truly stock, you should have 3:08 gearing both front and back, if that is the case your speeds will be as described. I have no problems driving 80mph on the highway but usually keep it at about 70 to 75.
rsh4364
15
greensprings ,ohio
Im ready to pull the trigger on a rebuilt IP,injectors,return lines,Can you PM me the contact info? Thanks.
