TechnoWeenie
1,669
Nova Laboratories, WA
Last night I about grenaded my rear end.. Pulled the cover to find missing teeth, and a bunch of metal shavings..
Picked up another 10 bolt LSd at a junkyard.... looks pretty good. Some wear on the teeth, but should last me another 50K+
I also picked up some sliders... The rear axle and the rear side sliding windows, all which were like brand new, set me back about $300..
They have an M1009 there, but it just came in, doesn't have its 'papers' yet.... :(
swiss
856
Oakwood, Ga
New shoes, bfg radial TA
33x12.5 r15, no rub, no lift just right
$850 all in, I was happy
swiss
856
Oakwood, Ga
Stock rims? Mine are 16". Or did you buy some other rims, too?
Nice, either way! :beer:
Thank you Marcus, stock standard 15" M1009 rims. Never seen 16 on a CUCV but I never saw a lot of things :)
Just cleaned all the electrical connections on those pesky relays under the dash and got my voltmeter working again!!!
i am going for a ride. Now I got to get a spare, I did not have my spare rim with me last Friday.
TechnoWeenie
1,669
Got a replacement rear from the junkyard, only to realize it was an open and not a locker...
So, got to take it back tomorrow, and hopefully they'll have the one I need...
swiss
856
Oakwood, Ga
Trucks (m1008, 1028,1010, 1031) have 16" wheels. m1009 has 15" wheels. 15" will not clear the brakes on the 1-1/4 chassis.
That is why the SS community is so awesome, you can learn something new every hour! Thanks for posting clarifications
soulbrojosh
albion, mi
I just managed to strip out the end fitting on the new Upper oil cooler line i was installing!!!! Does anyone know of anyone who sells the lines with something other than aluminum fittings?
00Buck
Racine, Wi
Spent my birthday with my father tearing into the front end of my 1028. Would start a death wobble when braking from 55 for a stop light with an instant on/off yellow. Noticed the brakes had a little pulse like they were warped; which would initiate the wobble. Had the rotors turned and thought it would be smart to replace the u-joints on the front axle while I was there. Had a heck of a time getting the old joints out with large bench vise and sockets. All back together and seems to be good. Turning rotors 24$, Seals for hubs 34$, one outer bearing set 13$, two u-joints 76$, spending a day wrenching on a fun toy with my 76 year old father I hadn't seen is 18 months... Priceless. Blessed Memorial Day to all.
lostintexas
Houston, TX
Son and I replaced belts and hoses on the M1009 today. Needed to replace the heater core but decided to go the cheap route and just install a by-pass until a little $$$ came in. Had to search the forums a few times for belt routing and correct belt sizes.
Everyone have a great day tomorrow!
