zout
- 154
- 63
- Columbus Georgia
I realize it vents - when shut down it vents off the tanks and its not within reason it can empty the tanks in less than an half hour once the engine is shut off an no longer building air. If the engine is running and you do a brake pressure cut out test and pump the brakes till your protection valve pops it will pass. If you shut down your engine and perform the test as well as the system self venting itself it will still do the same but only sooner.
The tm explains this thoroughly.
You stated during operation it vents - it only vents when shut down.
