acme66
Plains, Montana
The other front had some dark grease but they cleaned up spotlessly. No contamination into the driveline just the bearing. Hub seals were good, I have no idea how it got in there or how long. Years and years and salt water is my guess. The wheel ran cool, tight and quiet. I was in there to change an axle boot and was surprised to find all that. It will be better soon. I have not pulled all the rear axles yet but the oil is clean and dry in the rear ends so I bet they are all fine. On the list regardless.
Ken
74M35A2
317
Livonia, MI
I installed locking door locks and fixed windshield washer bottle. O and topped off my motor oil.
What was the issue with your washer bottle, and how did you fix it? I have a 939 series, and the metal threaded hold-down ring on the washer bottle pops off when the jar is pressurized. The vent in the top plate is clear and working.
I'll start a new thread on this, but if your situation was the same, please indicate your resolution. Thanks.
Artisan
227
CDA Idaho
Somebody needs to find a GLASS JAR w/ lid that we can apadt to and
replace this plastic pos.
tbar123
24
enon,oh
I took a dead bird out of the bed!!!! I also found out that my wheels were green,then tan,then green,and finally black!
Ddmk18
James Creek PA
I will get pictures of that tonight. I put a filter setup under the hood that's plumbed in line with the original pipe. It's a K&N for large diesels
