2014 VIN Info Thread
CARNAC
The Envelope Please.
620
Corpus Christi, TX
Carnac
serial c52307531
identification nloksy c52307531
nsn 2320010502084
truck cargo, 5 ton 6x6 m923 wo/w
purchased from government liquidation
front markings wz4n99 d0060
rear markings 11th avn hhc108
Thank you This is my first truck
Valpo deuce
Nope, go back and read post 1 rule 2. Failure to follow instructions
Valpodeuce
Valpo in
Sorry Carnac, I will try it again
A) Serial no: 52307531
B) USA no: NL0SKY
C) NSN: 2320010502084
D) Indianapolis 2013
E: Markings front WZ4N99 D0060 rear 11TH AVN HHC108
Thank you once again. Hopefully, I got it right this time.
CARNAC
620
Corpus Christi, TX
1971 M35a2 W/W
a. Serial Number 04J69771053912416
b. Registration Number ?
c. NSN 2320000771617
d. Where you bought it Private seller Treverton Pa
e. Bumper numbers Painted over but the glove box had 04J69771
Contract # DAAE0670C0001
Organization: USPFO ACTIVITY PENNSYLVANIA ARMY NATIONAL GUARD
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2 W/W NSN:2320000771617
Serial Number: 53912416 Registration Number: 4J69771 Year of Mfg: 1971
Info Jun 2011
CARNAC
620
Corpus Christi, TX
Carnac,
M916
A) S/N 1172006
B) Reg NP02QF
C) NSN 2320010284396
D) From GL Tennessee
E) Bumper number 36BDE326E
Thanks,
Ken
Organization: 4TH ENGINEER BATTALION, FSC EN BN
Nomenclature:TRUCK TRACTOR LET Model:M916 NSN:2320010284396
Serial Number: OT58146610351 Registration Number: NP02QF Year of Mfg: 1979
Manufacturer: 65909 Contract Number:DAAE07-77-C-4211
Info Sep 2005
Looked up using reg num, meaning you probably need to verify your serial number since the one you provided didn't bring up anything.
CARNAC
620
Corpus Christi, TX
B) USA no: NL0SKY
Organization: HHC, 11TH AVIATION COMMAND
Nomenclature:TRUCK CARGO D/S 5-TON Model:M923 NSN:2320010502084
Serial Number: C52307531 Registration Number: NL0KSY Year of Mfg: 1985
Manufacturer: 65909 Contract Number:DAAE07-81-C-5597
Info Dec 1993
CARNAC
620
Corpus Christi, TX
This is a M931A2 Tractor purchased from Ft. Worth, Tarrant County, TX GL site.
a) Serial No: 1044AA022
b) USA No: NL0U0H
c) NSN No: 2320012300302
d) Ft Worth, Tx
e) N/A
Other numbers that may have value (ref. Picture and typed below so you can cut and paste if they can help):
19207125050430521044AA022NL0U0H
W911SE07D0026
Organization: 1011TH QUARTERMASTER COMPANY, 3RD PLT, AREA SUP A4
Nomenclature:TRUCK TRACTOR 5-TON Model:M931A2 NSN:2320012300302
Serial Number: 3100655 Registration Number: NL0U0H Year of Mfg: 1990
Manufacturer: 47457 Contract Number:DAAE07-86-C-J111
Info Feb 2012
131
dickinson,tx
Carnac, Ok...rght off the bat I know im more than likely going to be beat about the head and sholders so I am prepaired. I am looking for info on my m925a1
here is what I have:
A) Serial #: C52501303
B) NSN#: 33341793045603......I have read through most of the threads looking for a similar NSN# and have found nothing ie:232. but the numbers on the frame are clearly 333.
C) Reg#: N/A
D) Bumper#: N/A
also I have no data plate in the truck. nothing to ref. to.
thank very much for any ifo you can help me with. and please be easy with the whip im a newbie.
CARNAC
620
Corpus Christi, TX
333###.... is a manufacturer frame assembly number. It is not your NSN. Did you have a data plate on the dash (post 148 on this thread shows a picture of what it should look like)? I'd also search on that frame until you found the C52501303 on it to validate the truck.
Bluebeard
Truckee, CA
Carnac- can you please look at the info I provided and perhaps run it through your system? I have an appointment with the DMV on this coming Friday and I'd like to have as much info I as I can get for them. My posts were not intentioned to piss you off. I was just suggesting that the instructions given could be a little clearer. You need to tell people that the "O"'s and "I"'s AND ANY "Letters" in any of the words written on the trucks ARE IN FACT, Zeros and one's. That's all, and most likely people will get it.
131
dickinson,tx
the truck did not have a data plate on it. I found the c52501303 number on the frame drivers side. so really thats all i have unless there is another place that the NSN number would be on the truck. I bought it second hand so maybe the guy I bought it from has the data plate. thanks
131
dickinson,tx
Carnac, I found the Reg# info from the previous owner. but still no NSN # I don't know if the Reg # helps you any more than the info I previously gave you. Thank You Sir.
A) Serial #: C52501303 Here is the complete number: 1920712505043003C52501303
B) NSN#: still do not have. plate was taken off truck
C) Reg#: NL0C6L
D) Bumper#: N/A
darkstar
Plano, Texas
Donation coming forth, CARNAC, if you can dig up some info on my vehicle.
M35A2 Cargo W/OW
MFG: Kaiser
VIN: 012511072 (The number 1 is over-stamped on TOP of a number 7 on the instrument panel data plate.)
REG: NK0DV8 (Also stamped on the USA instrument panel data tag, and overstruck with dashes and painted over, is 4H1766. Both of these Reg/USA numbers are stenciled on the passenger door.)
NSN: 2320000771616
Data tags show that the vehicle was put through Tooele Army Depot in September 1987 for repairs made to "FORSCOM / NGB Work Requirements", and new CARC paint.
All bumper numbers have been painted out and are unreadable, so far.
I purchased the vehicle from an individual who originally acquired it at an auction in Oklahoma City in late 2010.
Thanks CARNAC
Bluebeard
Truckee, CA
OOO Upper case letter "OH"
oooo Lower case letter "oh"
000 Number "Zero"
I'm confused, Bluebeard????? I know what CARNAC means by using numeral zero instead of alphabetic letter "OH". Where have I used the letter "OH" instead of a zero in my submitted data plate numbers?
FORSCOM should be F0RSC0M
His description doesn't clarify letters in words is what trips everyone up.
darkstar
Plano, Texas
I may be mistaken, but this is what I think these two "words" mean":
FORSCOM = Forces Command
NGB = National Guard Bureau
I am still somewhat confused by what you mean??
Do you think CARNAC wants all of the prose and correspondence in all the reply posts in this particular thread to not have the letter "OH" but the numeral zero, instead??
I don't think that's what CARNAC is implying?
The actual data plate ID, VIN, Serial, USA, DOOR, etc. NUMBERS - YES! --, everything else -- NO!
