trooper632
- 3
- 18
- Utopia, TX
OK, I have looked and read related posts trying to find my issue, This is the issue.
1. Glow plugs don't heat up, though maybe gp relay might be bad, hear the clunk of it when key is turned but it cycles on and off repeatedly.
2. I put a manual momentary switch on thinking maybe that would work, seemed to, push button hear the clunk and goes off when button released.
3. Still not heat at glow plugs, but it seems to be getting power to them, checked with light tester, when button pressed tester lights up very bright (24 volts getting to it) while toughing glow plug spade. (Each one)
4. Changed out glow plugs, Nothing wont start, use just a little starting fluid (I know DONT) but just a little and it starts.
Could the glow plug relay still be bad even though it seems to be getting power to the plugs, The plugs are not new but take outs from another vehicle, I am not for sure if they all work, but I figured they all could not be bad, they did start the other vehicle when last started.
What next???
What next???
