- 1,958
- 426
- 68
- Culver City, CA
This past weekend we installed a second set of shackle mounts underneath the front bumper. In doing so some of the hardware had to be replaced due to new thicknesses.
We also removed the windshield hinges. They were a bit frozen up and deserved a coat of paint. I soaked them PB Blaster and got them freed up nicely. There was a lot of rust on the old bolts. I backed those out with some light impact wrench, but still sheered two and lost threads in the mounting hole on the lower right windshield. Took me about an hour to get the two sheered bolts out with some PB and vise-grips. Using an angle grinder wire wheel, I knocked off the surface rust at the mounting locations and then threw a coat of paint on them. I reinstalled the hinges with new grade 5 bolts and lock-washers. I still have to install a threaded insert on the one hole.
