My fire department just received a M1078 through a forestry service grant to be converted into a fire truck.
1) I discovered two hydraulic lines that run to the passenger side front axle housing on the top had sheared off at the fittings causing fluid to leak when I test drove it. I am trying to figure out the fluid that goes into there and where it is added.
2) what type of fluid is it? I looked in TM but it is in military spec.?
3) is there a place to get military fluids? or figure out civilian equivalents to the mil. fluids.?
4) I am trying to find a 12v access point to wire the radio, siren, light bar to, any ideas?
Thanks, Ill post pictures when it is all done with its new paint job.
