bonesfixed
- 0
- 0
- Lawrence KS
Is the engine ground on mep-003s positive or negative?
I thought the same thing.Seriously?
Possible his cables weren't connected, or even present?The fact that the - cable goes from the battery to the frame is a dead give away.
That makes sense now. I apologize.When I picked up my Mep-003a from GL the red cable was connected to the frame and black cable to the starter, which could give anyone good reason to double check.
Ditto - The very first MEP 002A I picked up also had the red cable connected to the chassis and the black cable to the starter. I wonder if somebody did this to be "cute" or what. I hooked the red cable to battery + and black cable to battery -. After rebuilding 8 MEP generators I know better, but on the first one I did not. I was fortunate I did not cause any permanent damage.When I picked up my Mep-003a from GL the red cable was connected to the frame and black cable to the starter, which could give anyone good reason to double check.
