scottmh
- 0
- 0
- Houma, LA (bottom uda boot)
That's the best way to go.
30 ampWhat amperage do you guys suggest? I plan on installing a panel box to run a/c along with the lights and outlets
Also. For the 24volt lights I had them working then I switched the blackout switch and now the two center lights will not come back on no matter what I do with the switches. Any ideas?
Is it wired that they only come on when the doors are closed?30 amp
Pull switch out and check if switch is still good, and check the door switch.
With the blackout switch on the lights will turn off when door is closed, and if you have the blackout lights on they will come on.Is it wired that they only come on when the doors are closed?
