Striped 6inch shackle bolt for m101a3 surge brake.
bigbe5678
22
Pearl River NY
Hi Everyone I accidently striped one end of the 6 inch shacklebolt that holds the shackle on the m101a3 surge brake.houseing. Does anyone know where Ican buy a replacement? It’s the one of 4 on the surge brake housing that hasthe nylon bushing associated with it. Thank you Mikeaua:?:
ke5eua
41
Baton Rouge (Central), LA
Are you talking about these, if so just get some grade 8 bolts from your local lowes or home depot and call it good. As long as you retain the nylon bushings and don't over torque you'll be good.
juanprado
2,898
Metairie/La (N'awlins)
A bolt might work but it is actually a double ended stud with a nut on each end with the nylon bushings. On mine the nylon bushings were bad and I changed them out when I had to do the shock.
Croft trailer sells all the parts as it is a common civy unit- check out
http://www.crofttrailer.com/hydro-act-brake-actuator-parts/
Attached is also a parts break down.
bigbe5678
22
Pearl River NY
Holy crap! $25!!!!?
I might have one, PM me this Friday.
Hi Chris Don’t worry about looking for that bolt. Iwas able to have my local mechanic re thread it. By the way that bolt costbetween 40 and 55 clams 25 for bolt and croft wants 15 bucks shipping Check it outThanks again for your concern Best Mike
