RAYZER
- 58
- 48
- sanford/florida
Working on it!Ray, you are going to need a bigger trailer. You pretty much have that one filled up inside and out!
That's awesome and you could pull a support trailer behind as well!
I have a Teflon disk on my trailer fifth wheel plate (no grease needed), using the ramps tends to tear it up.
Found out the guy that picked up my ex-M348A2 also towed a M1008 behind it to it's current location.That's awesome and you could pull a support trailer behind as well!
That would have been an interesting pic!Found out the guy that picked up my ex-M348A2 also towed a M1008 behind it to it's current location.
I wish he had sent me a pic of that!
Do you have any data as to how much weight that type of trailer tandem hitch is rated to pull?
The m146 is not set up for tandem tow, it would be nice to be able to pull a small lightweight support trailer behind (like an 1101),of course that would require a permit.
I have very little support storage capability when taking a rally trip.
Sounds like a plan!Thanks Rayzer, mine also came with NOS NDT 9:00X20's but hooked up to my M932A2 its at a pretty significant rake. I'd like to get 14RX20s under it. I have a bunch of NOS Goodyear 11RX20s but they only give me 3" of lift over the 900's. The NOS BUDD axle will give me spring brakes too under the M146. So the decision is modify the converter dolly and get rid of the so called Calif wheels and mount the 11R20s on the dolly and M146 and pull it via pintel or mod the M146 with the BUDD axle and mount 14R20s and have spring brakes. Decisions...
Not much, but better than nothing.That would have been an interesting pic!
