Carlo
- 20
- 0
- palazzago italia
Last Sunday I had my A1 and A2 out on a soft air tournament rental. The A1 started leaking just a little bit. The leak is coming from the tray below the radiator. I can see no direct leaks from the radiator. The upper and lower hoses are dry.
One thing strange is it will only leak when running and less than a minute after shutting off the leak stops. This happens even with the radiator cold or hot. I would think that if the radiator had a hole it would leak even with the motor off but this leak stops shortly after the motor is shut off and as soon as the motor is running ( seconds after) it begins leaking. It sounds like a water pump failure but under the pump it's dry plus the leak comes from under the radiator.
I have not had time to remove the shroud. That will be done this week. Maybe With this shroud off I can see more.
Has this happened to anyone?
thanks
thanks
