- 439
- 47
- 28
- Blythewood, SOUTH CAROLINA
Hey guys. I am moving the axles on my 925 to match a 931. I will also be adding a sleeper, air ride seats, round tanks, pyro, turning it up and governor springs. I found all the dimensions from a 931 data plate, but the rear drive shaft flange looks too close to the hitch cross member. I'm 46in from rear frame to center lift point on axles and 53in from tip of pintle hook to same place on lift point. Is there a difference in hitch cross members or can some one pull a measurement from the drive shaft flange to closest crossmember on a 931? I am getting ready to drill a lot of holes and would like it to be in the correct place. Picture is from over head. Any help would be awesome thanks!
