andy3
- 12
- 18
- Suwanee, Ga
I have a dead Deuce motor. The short story is I was driving along and had good power, heard a thunk, engine shut off and I coasted to a stop. The good news is I was able to setup for a recovery safely and Swiss and 73m819 were able to swing back and snatch me off the median quickly and safely. Ron has been VERY gracious and helpful The truck is currently at his motor pool cutting down on the grass he has to cut. The Deuce looks like a child in a farm of 5tons. Teardown shows something bad happened. It appears I broke the end off the cam or something equally as gruesome. So I live northeast of Atlanta and looking for advice and leads on a motor. I spoke with gimpyrobb and he has a motor that is a possability, but I would be looking at delivery @ the rally.
This is not something I had budgeted for but, I do have a few man toys That I should really sell to make yard room and pay for this bump in the road.
I’m not sure if this should be in this forum or the parts wanted. Mods please move if needs to be.
To quote Ron:
Ya, I was so into the ip and once I saw that the HH was good and still not working that I did not think beyond that, In the ip under the HH there is a snap ring then a plate, then a coil spring, then the roller cam follower, this cam follower was stuck in the bore, had a heck of a time getting it to pop up and out, apon inspection of the follower I saw FRESH gouges and scratches, this is matched machine surface with the bore, the tm says there is NO replaceable parts other then the HH. It bothered me on where the metal came from to cause the follower damage, though I was still thinking ip, this morning I remember that on Sat. Andy said "I heard a THUNK and the truck shut down" being a bad ip does not go thunk, the question was what would all the while still screwing with the ip, then the light came on after taking stock of a few other signs that the cam had died, either sheered the key or broke right behind the drive gear, pulled the valve covers, turned the engine over, NON of the rocker arms moved, proved my broken cam idea. The tore up ip is collateral damage from the cam dying, hence the fresh scored up cam follower. I hated to make that call to Andy, I would have liked to call and say "your truck is on the front lawn, ready to go home any time you want to come and get it".
To quote Ron:
