I don't buy that. I have a extensive background in things like this. Been a aviation A&P for over 20 years now. A battery (unless it is shorted will not cause a alternator to fail). A bad battery will just refuse to take a charge and will not be any load on a electrical system. Since he knows the cause of the weak batteries (the switch was left on) then they are just low and charging them enough to start the truck will be all that is needed. Even for our aircraft if the battery is weak because of being left on, we are allowed to jump start the aircraft and allow the aircraft's electrical system charge them up. Now if the battery is down because of unknown reasons then we are required to change the batteries. Please explain to me how a bad battery (not a dead shorted on) will hurt an electrical system. If you can then we can continue this discussion.On the electrical system on the 939 series trucks trying to charge bad batteries will most certainly cause generator failure.....
I agree with what's quoted...... Since he knows the cause of the weak batteries (the switch was left on) then they are just low and charging them enough to start the truck will be all that is needed....
Not saying things don't happen, but they are almost always the result of a messed up system. If a weak battery hurts your alternator than you have other issues with the truck. Like I said something like a internally shorted battery could cause issues. A bad regulator could hurt things, but this guy knows his batter is dead because the switch was left on. Millions of people jump start trucks with dead batteries and then take off driving with no issues. Heck I had a 2005 nissan titan that would sit so long it needed a jump start every time I used it. Never did it hurt the truck, the battery would charge up and start the next time just fine ( as long as I didn't wait too long).I agree with what's quoted.
I won't pretend to know more than I do about the electrical systems. I can't tell you *why* or *how* trying to charge bad batteries with our 5 ton trucks will result in failure. HOWEVER, there are simply too many examples of people that have fried a generator doing it for it to be coincidence: mechanism of failure not understood, but result fully understood.
I've done it a bunch on other vehicles also. It would never have occurred to me that it was a bad idea until I read about people having problems with it on these trucks.Not saying things don't happen, but they are almost always the result of a messed up system. If a weak battery hurts your alternator than you have other issues with the truck. Like I said something like a internally shorted battery could cause issues. A bad regulator could hurt things, but this guy knows his batter is dead because the switch was left on. Millions of people jump start trucks with dead batteries and then take off driving with no issues. Heck I had a 2005 nissan titan that would sit so long it needed a jump start every time I used it. Never did it hurt the truck, the battery would charge up and start the next time just fine ( as long as I didn't wait too long).
I would be willing to bet those cases the generator was probably part of the reason why the batteries where dead in the first place. The big pull on the weak/bad generator just was too much for it to handle. Weak batteries won't take lots of amps no matter how much you put on them. The only way to get a battery to pull lots of amps is to put a load on it. That is why if you have a really dead battery and you are trying to jump it and it won't take a charge, you put a huge load on it, then it will start taking the charge. Ever seen when you put a battery charger on a battery that is dead and the amp meter only goes up a few amps. Then if you hit the starter while it is charging then amp meter will shoot up to 10 maybe 20 amps.I've done it a bunch on other vehicles also. It would never have occurred to me that it was a bad idea until I read about people having problems with it on these trucks.
I recently recovered an m925, with utterly dead batteries. Before reading here I would have simply slave started it and driven it a few hundred miles before shutting it off. Instead I changed out the batteries. You'll read multiple accounts where people have done what I would have done and as a result they added generator replacement to the battery replacement bill.
I dismissed the first couple of accounts as coincidence, but there's simply too many cases of it happening. I still can't tell you the mechanism, but empirical evidence always precedes full understanding.
Back on topic regarding the OP, his batteries weren't utterly dead or bad, just mildly discharged. Slave and go.
But let them sit with the lights on for four years or so and then try it and you'll buy a new generator.... too many cases for it to be coincidence.
What is the voltage of the solarizer? If 24 volt the hook to both batteries. If 12 volt, then hook one to each.Quick new question. My truck has 2 small solargizers when going to 2 batteries do I hook 1 to each or only use 1 for the pair? If 1 for the pair where do they connect?
They put a lot of stuff in manuals to CYA..I see it all the time.. YMMV
Haha I guess that should've been obvious. I'll have to check them when I get home. I guess I figured they were all the same.What is the voltage of the solarizer? If 24 volt the hook to both batteries. If 12 volt, then hook one to each.
Many on this site do, and mine will soon.5 ton trucks do not have electric winches.
Good post.Helomech - I understand what you have been saying and agree that generally, you would be correct. I also have extensive experience in electricity, both stationary and vehicular and would have been prone to stating just about what you have. However, it has become apparent to me since being bit by the green bug that the regulators on these alternators do in fact, have a high incidence of failure due to dead batteries. When the regulator fails, it does so in a manner that drives the alternator output to maximum.
My theory: So, when you first start the truck by slaving, all is cool. After a while, the regulator overheats and alt goes to full voltage. The batteries take what they can for as long as they can, then the system voltage starts to climb. Soon after that, the smoke is let out from all manner of places. Wires burn, gauges burn, sending units burn, protective control boxes burn, alternators burn.
My deuce had all of the gauge coils burnt, the oil pressure, temp, fuel sender, and regulator burnt. Both batteries were completely dead but were recoverable with many days of slow charge. They continue to serve some 2 years plus later.
Respectfully, my 2 cents.
EDIT: Tech schooled in auto mechanics specializing in electrical systems, F-4 Phantom electronics technician, industrial electrician, instrumentation technician, stationary generator technician, etc. The F-4 part is a clue to how long I have been working with electricity.
