ke5eua,
I have to respecfully disagree with your statement. From the TxDOT Commercial Driver's License handbook -
Different Classes of Commercial Driver Licenses
There are three (3) basic types or classes of Commercial
Driver Licenses. They are described below. For further information,
refer to the diagram on page ix. This diagram helps
a person determine which class of license he/she needs and
which section(s) of the handbook to study.
CLASS A: Any combination of vehicles with a gross combination
weight rating of 26,001 pounds or more,
provided the gross vehicle weight rating of the
vehicle or vehicles towed exceeds 10,000
pounds;
CLASS B: Any single vehicle with a gross vehicle weight
rating of 26,001 pounds or more, any one of
those vehicles towing a vehicle that does not
exceed 10,000 pounds gross vehicle weight rating,
and any vehicle designed to transport 24
passengers or more, including the driver; and a
Class B license will be restricted to operating
busses under 26,001 pounds GVWR if the skills
test is taken in a bus with a GVWR of less than
26,001 pounds; and
CLASS C: Any single vehicle or combination of vehicles
that is not a Class A or Class B if the vehicle is:
1) designed to transport 16 to 23 passengers
including the driver; or
2) used in the transportation of hazardous materials
that require the vehicle to be placarded
under 49 CFR, Part 172, Subpart F.
It is pretty clear that operating any towed vehicle with a rated weight over 10,000 lbs requires a Class A driver's license, irregardless of the requirements of the towing vehicle. Towing a deuce with a deuce on a Texas public road requires a class A license !
The Texas non-commercial definitions are virtually identical. The actual state codes are in the Texas state laws thread, if you'd like to see them.
