dilligaf13
- 33
- 28
- south, florida
I'm using M35 front springs to bob an old M813. My question is, what do you do for spring perches?
The M35 spring perch obviously isn't big enough to fit on the 5 ton axle so I'm thinking of using 5 ton perches but then I run into the issue that the M35 spring is 2.5" whereas the 5 ton spring is 3" wide. Thoughts?? Thanks.
