bchauvette
- 12
- 0
- Easley SC USA, 29640
Would dry ice be too radical? would warming the hub help? Not red hot but warm.Freeze it then install
I was using a pilot tool, set it straight and when I started tapping it in it went crooked, getting it out is where the fun was.How did you get the seal sideways enough to bend it? Did you put it in and start wailing on it? I have always tapped in the seal with a suitable driver and pilot tool, if it starts to turn you can always tell if you look at it frequently and straighten it out. I've had plenty try and twist out, but you watch for that.
The key is go slow and check your progress frequently. There's no way to mess up a seal if you take your time installing it. Good luck on your next attempt.
For sale ads have to go in the classifieds!!!For sale truck needs seals
Yeah whyMy goodness... Do you have a bench grinder there?
