Relocate Deuce heater into the cab
Ok, so I am just about done with my heater install. I have a 1985 M35A2C that I put a hydro power steering system into it from an M818. On this steering system, the gearbox is on the steering column. Therefore, I needed to relocate the cab heater. My options were to relocate it to the other side of the engine compartment, or to the inside under the dash on the passenger side. Inside the cab is where it went, and I got a diverter box from a 5-ton truck and a heater core from an M35A3. Here are a few pics and comments:
The first thing I did was remove the old system. Since the new system will pull air from inside the cab, I removed the old air vent in the firewall on the driver's side that routed fresh air into the cab. I bolted 1/8" steel plate on both sides of the firewall, because I have zero welding skills. On one side, I used some RTV silicone to give it a good seal. I used 8-18 stainless steel bolts, as there won't be any stress on these joints. Here is what that looks like from inside the cab and from the engine side:
The next thing I did was measure where the heater box needed to go. I didn't want to cut it down, as that would test the limits of my zero fabrication skills. So I marked off the farthest it could go to the right side (passenger side) and still allow for the operation of the fresh air mechanical vent. So, I needed to shorten the connector piece from the heater core and the air diverter box. I made a piece from 4" inside diameter (ID) exhaust pipe that would fit over the input end of the diverter box and the output end of the heater core. The piece is 1 9/16" wide, and has four holes drilled in it on each side. On one side (the diverter side), those holes are 1/4" from the edge. On the other side, those holes are 1/2" from the edge. I then ran cutting screws through those holes to get everything connected. I took this approach because I have zero welding skills. Here is a before and after shot of the 4" ID exhaust connector:
To get the coolant hoses through the firewall, I used a couple "military grade" rubber grommets I got from Grainger. They were 1" ID and needed a hole through the firewall of 1 3/8". The coolant hose I used was 5/8" ID Dayco silicone heater hose that had a 0.995" (1") outside diameter (OD). I used constant pressure sprint-type hose clamps. Here's a couple photos that show where the coolant hoses came through the firewall first from the inside then from the engine side:
Next, I connected those hoses up to the coolant system. The top port I used before the thermostat was a 1/2" pipe fitting. The bottom port by the water pump was a 3/4" pipe fitting. I decided to replace the drain cock 3/8" pipe to 5/8" hose that the military uses with ball valves. I had a couple 3/4" ball valves laying around, so I used those. The bottom port connection was easy - I used a 3/4" street elbow into a 3/4" x 1 1/2" nipple into the ball valve. Then I used a 3/4" pipe to 5/8" hose barb coming out of the ball valve into the hose. I connected the hose with the constant pressure sprint-type hose clamps. I'm not sure what those are really called ... For the top port connection, that needed a few extra pieces. I started with a 1/2" x 1 1/2" nipple and went into a 1/2" elbow. Then another 1/2" x 1 1/2" nipple into a 1/2" input x 3/4" output connector. Then a 3/4" x 1 1/2" nipple into the ball valve and a 3/4" to 5/8" hose barb coming out of the ball valve. Here's a couple pictures of what all that looks like:
Next, I flipped the motor to the other side of the heater box. Instead of the motor hanging down, I now have it sitting above. There are no clearance issues with the map box. I also removed the elbow air intake to increase foot space below the heater assembly. I still have to get some sort of screen on that air intake opening. The military didn't have a screen, but it seems like a good idea, and I'll get it done. Here's a picture of what that looks like:
Here are a couple pictures taken from looking through the open map compartment. This is where the two mounting points for the right side of the heater core attach - to the bottom support bracket under the map compartment. You can also see the bolt through the firewall for the rear left mounting point on the heater core.
Here's a couple shots of where the diverter box is positioned. I needed to use 3/4" spacers to hold the diverter box off the firewall - because I no longer had the flexible hose connecting the diverter box to the heater core. The diverter box has moved about five inches over to the driver side from its original position. It also moved down about four inches from its original position. Those distances are estimates, and you should measure your system several times before drilling any holes.
Finally, here are two shots of the system in its final resting place. So far, I don't have any leaks. I consider that a victory. Unfortunately, I ended up with several extra holes through the firewall. I'll fill those with hole plugs one of these days. I hope you like the pictures. Any feedback you have on how I could do this better would be greatly appreciated.
