- 1,918
- 19
- 38
- Bradenton, FL
Pictures would be nice....
If you're talking about the CCUV consoles I think he had pics posted.Pictures would be nice....
Do you have 2 available?1/2 Slide-In, holds 2 batteries.
They should be 16" x 12.5" x 9.5" (L x H x W)
Only one.Do you have 2 available?
Rats, I'll have to pass then. Thanks.Only one.
Only if you come down and get them!
Hey what are those good looking trucks in the background Looks like a nice 923 and M62 WreckerAlso for your consideration: I have a decent M931A1 up in GA along with an M1101. Accepting reasonable offers to keep me from having it hauled down here to FL. Runs good.
I'm digging it, if you had to rate it on a 0-10 scale of work needed where would it fall? I've seen it in the classifieds just passed it over many times because it looks like it needs more work than what it's worth.I'm posting this here because it's been in the classifieds and has not moved. I still have the missile command trailer and I want to get rid of it. If I have a buyer I'll try to have someone haul it to the rally.
This a pretty cool trailer. If you saw Walkerhunters mobile hooch last year you know what can be done with these trailers. Yep, they are a pain to maneuver but you just don't see a lot of them.
I'm asking 1400.00 cash but I might take part of that in trade if you have something I can't live without. The trailer has issues, the roof has leaked for a while and the interior needs lots of love. It is wired for 110/220 and has a breaker box inside. The tires have very good tread but they are old. I think it has the same size tires and rims as the M37 family of vehicles. It pulled good back from Redstone at 65mph behind the M927.
Need 2 cheap yet servicable mechanics creepers that are the type used by the military.
Manufacturer Information:
4910-00-251-6981 64067 SOURCEAMERICA
A-A-50313 81348 FEDERAL SPECIFICATIONS PROMULGATED BY GENERAL SERVICES ADMINISTRATION WASHINGTON DC D 91770 R AND L MFG CO INC
KKK-C-650 81348 FEDERAL SPECIFICATIONS PROMULGATED BY GENERAL SERVICES ADMINISTRATION WASHINGTON DC
KKK-C-650 TYI 80244 GENERAL SERVICES ADMINISTRATION FEDERAL SUPPLY SERVICE
KKKC650C 81348 FEDERAL SPECIFICATIONS PROMULGATED BY GENERAL SERVICES ADMINISTRATION WASHINGTON DC
M 36540 LISLE CORPORATION
97502 36540 LISLE CORPORATION
97302(C) 36540 LISLE CORPORATION
Techincal Specification:
GENERAL CHARACTERISTICS ITEM DESCRIPTION MALL WOOD CONSTRUCTION FLAT BED; SINGLE WHEEL TYPE CASTERS MOUNTED DIRECTLY ON BED; PIVOT PIN SWIVEL CASTERS; 0.500 IN. MIN FLOOR CLEARANCE; 35.000 IN. MIN LG; 14.500 IN. MIN W; 3.750 IN. MAX H EXCLUDING HEAD REST
NONDEFINITIVE SPEC/STD DATA I TYPE
To put a decent paint job on the outside it needs to be either media blasted or a lot of hand sanding to remove loose paint. The roof leaks around the hatch on top but Cool Seal would fix that.I'm digging it, if you had to rate it on a 0-10 scale of work needed where would it fall? I've seen it in the classifieds just passed it over many times because it looks like it needs more work than what it's worth.
To me the frame is whats worth something. Is it a solid frame with the box attached or is the box part of the frame?
