It's about time I did some PMCS on the fleet. Being that temps are above freezing and ice is off the roads its not a bad time to start.
I had some big personal events take place last year and in the wake the trucks and equipment have to find a new home. Not a new owner but a new home. So in preparedness for the trip and most likely long storage ahead and because some are in desperate need of MX. I decided to get my task underway.
I decided to start with the M871, mainly because it's going to be loaded and lets face it aside from shear weight, its a pretty simple piece of equipment.
My goals before moving are;
-Tire service
-Brake Service
-Lubrication
-Electrical Inspection
-Deck Replacement
-Custom Bows/Tarp
-Rust removal/paint
I started the ground work for the trailer deck repair with this thread;
http://www.steelsoldiers.com/showthread.php?123705-Re-decking-M871-what-material
In the mean time I decided to work on the rest. I'm fairly mechanical but often get squirreled, so this thread may bounce a bit.
Yesterday I started deck removal, but I'm a horrible picture taker so you'll have to take my word for it. I certainly can't hear well today.
Tonight I finished the rear axle, well almost.
The TM doesn't specify tool sizes so I jumped into tire removal and brake drum removal to service the hubs. I started on Saturday but quickly discovered no place in town had the 3-3/4" octagon axle nut socket needed. So I ordered it and worked on the deck until it arrived today.
The second thing the TM doesn't describe is weight, the drum itself weighs a lot, if I were to guess it's close if not over 100 lbs. Now I actually own a wheel dolly and thought of using it however I wanted to inspect all the components, and both inner tires on the rear axle I suspected as having bad tubes. Knowing the weight I'll probably pull the front as an assembly.
For tonight's operation I used a cargo strap as a sling over my shoulder. Using my back in a twisting jerking fashion to hoist the drum and my hands to guide it on and off.
The third thing the TM doesn't mention is caging the brakes. It was kind of obvious to me and I'm not sure if the Army standard operating practice covers that but I expected to see brake caging as a prerequisite for the task, I mean caging the brakes is a procedure in the TM. Someone stole mine at GL or the army doesn't keep them on the trailer. I suspect the later as the USAF doesn't keep caging tools on the trailers either.
The forth thing I discovered the TM doesn't cover is volume of grease within the hub. I'd suspect over 3 lbs per axle and I used next to four packing it back up. I couldn't find anything that matched the mil spec so i just used NAPA's Extreme bearing and chassis grease, and will use it for other lube points as well.
All in all it went fairly easy and quick. The longest part was cleaning the grease from the bearings. The trailer had been recently serviced before I bought it in 2011 so the grease was really clean which makes the job faster. I don't own a bearing packer so I used the cupped hand method. These bearings are huge so it didn't work that well but not terrible. The TM says to remove and replace the gaskets but mine were good and I didn't want to try and find so. So if your following this you may want to find some before tearing apart your hubs. The inner seal is fairly durable but the outer seal under the cap is not.
So in addition to the TM requirements add;
1 Box of rags in a box
4 lbs of bearing grease
Hub sling or a friend
3 -1/4" Octagon Axle Nut Socket (outer nut)
3 -3/4" Octagon Axle Nut Socket (inner nut)
Brake caging bolt
Adequate lighting
I didn't find anything damaged or in need of adjustment within the hub or brake drum. The mileage I put on the trailer I think these will be lifetime brakes...
Cheers
-Tire service
-Brake Service
-Lubrication
-Deck Replacement
-Custom Bows/Tarp
-Rust removal/paint
Brake caging bolt
Adequate lighting
Cheers
