Official 2014 SS Georgia Rally Amateur Radio / Communications Thread
swbradley1
Modertator
1,628
Dayton, OH
This would be a solid performing system, However the rally coordinators did not appear to be interested.
Garret
W8BUG
That is why I broke off a separate thread, to get the people who are interested, interested and in one place.
Comm is something we have not spent as much time on and this year will be sort of a testing and evaluation year. The more bands and operators we have the better we can test on the trails.
As I have said before I still want to see the Georgia and Haspin Rallies connect up via radio.
And yes, I appreciate any help in doing all this.
CARNAC
The Envelope Please.
617
Corpus Christi, TX
Don't have time to read back through the 7 pages of threads.
We have 2 medics that are going to need comms. I found out we're going to have 4 trail rides out at the same time. I we need to shift the medic from one to the other, we gotta have comms.
ke5eua
40
Baton Rouge (Central), LA
ke5eua
40
My 30 seconds of free time is up. Oh well.
I was just worried about getting an infraction for the comment, lol
Comms shouldn't be an issue. Now me an napa might be one. 6 out of the 20 bosh type relays I got today are bad. Lucky I tested them on the bench before putting them into service. Would have been blown fuses, fried wires for sure.
Whiterabbit
14
Bristol Va.
The place is going to look like Division S6 by the time ya'll are done. :lol:
(A) What is the admin freq?
(B) What is the open/common freq?
(C) Will the official rally freq be within the range of common military radios? IE...RT524's,PRC77's?
Thanks
SCSG-G4
PSVB 3003
3,272
Lexington, South Carolina
Thanks
A - 2 meter (146.500 Mhz)
B - 2 meter (ditto plus GMRS - 70 centimeter)
C - 6 meter (51.000 Mhz)
And I'm WQTQ575 on GMRS!
scottgs
Oak Ridge, TN
Thanks
51.00MHz is what you will need. Just like last year. Did you get that audio problem worked out? I can't remember if we fixed it before the end of the rally last year or not. Also, I'm working on the SIIA grill. You have SIII now, correct? Will the 151 have commo?
Garret
W8BUG
ke5eua
40
I know if you try to talk to mil radios with ham gear you need to use a ctcss tone. I spent a day figuring this out and I have it written down in one of my green books but it's easy to figure out if your rig has ctcss scanner built in.
The mil uses a non standard tone but I've been able to talk between ham gear and mil radios using the closest one.
Whiterabbit
14
Bristol Va.
Hey,
The M151A2 would have my extra PRC77 manpack and a GMRS hand held tossed in the ammo box/console. Still having issues with the speaker on the AM2060. Got so ticked off messing with it one day I haven't even fired it up in 6 months! LOL!
Yea, I got that cheesy S3 plastic grill, no sweat if you don't have one tossed in the corner of your shop.
SCSG-G4
PSVB 3003
3,272
PRC77's are only 4 watts, without a good antenna and an AM-2060 they are not much better than the GMRS HH's. Good antenna gives you an improved SWR and the AM2060 puts a bit more power in the output signal. Or, alternately, send the radio unit up on top of a hill, then try to talk.
kubotaman
124
RI/MI
Have you guys thought of tactical Cal signs. You use them just like your call sign with your call sign.
swbradley1
Modertator
1,628
Dayton, OH
I suspect that during the first full day of the rally all the amateur operators will be having a meet and greet at the command tent with the CO.
That way we can work on finalizing everything and talk about potential testing methodologies and getting CARNAC the coverage he wants for the medics. Unless someone sets up a 6 meter outfit at command all we will have there is 2 meter.
All suggestions and help are welcome. Let's come up with something year that we can have as a legacy moving forward and maybe even spread it to other rallies.
ODFever
Madness Takes Its Toll...
73
Orlando, FL
Great idea, Kubotaman! I like the idea of setting up tactical call signs. Our ARES/RACES group practiced that a long time ago, and it worked well once we got used to it. It helps easily identify the location of the ham, and helped expedite needed information.
Here are a few examples I came up with.
Medic {call sign} For emergencies: MAYDAY MAYDAY MAYDAY {tactical call sign, call sign} EMERGENCY MEDIC NEEDED AT {location}
Wrecker {call sign}
Since there are 4 trail rides happening at the same time, how about:
Trail 1 {call sign}
Trail 2 {call sign}
Trail 3 {call sign}
Trail 4 {call sign}
The tactical trail names could be modified to reflect the trail difficulty level.
Other thoughts: Assign tactical call signs to all stationary locations.
Other considerations: setting up a directed, controlled net vs. leaving the frequency open and quiet when not needed. Directed nets require slightly more manpower. Open nets are helpful when you're listening for emergencies or traffic. What do you think, Steve?
The main areas I can think of that require amateur radio operators in close proximity are the Medic tents, the Wreckers, and the trail rides.
ke5eua
40
Wrecker {call sign}
Trail 1 {call sign}
Trail 2 {call sign}
Trail 3 {call sign}
Trail 4 {call sign}
Couple things about that.
As long as it's a ham on the radio and no joe blow this should be fine but how are you addressing id'ing every 10 mins when using tactical call signs?
A directed net is fine, but not needed. Open frequency is just fine. Think about it.
Directed net
KE5EUA to Net control
Net control go ahead
KE5EUA requesting to direct to N5NIR
Net control roger, proceed
N5NIR this is KE5EUA, Paul are you there?
Nothing heard, back to net control
Net control, thank you, net control standby
Now we will use open frequency
Nothing heard, KE5EUA clear
Mayday is a no no, we are not in the sea. Now if it is truly a life or death situation then by all means use "break break break" instead.
