Which injectors for a turboed 6.2
Gunfighter1
AZ
So im in the process of making my CUCV my daily driver and want to replace the glow plugs and injectors while im at it. I did the turbo swap with a GM-8 turbo and all the 6.5 parts. Ive been looking at part numbers and trying to figure out if i should use stock 6.5 turbo injectors or just get new 6.2 injectors. If someone could provide a part number and source id appreciate it greatly! The truck is an 86 M1009 with 36K on it.
Skinny
492
Portsmouth, NH
I would probably consult a Stanadyne certified shop because your IP and injectors should realistically be a matched set.
Warthog
240
OKC, OK
Also depends on the heads and injector lines. Some use short and some use long injectors.
Gunfighter1
AZ
How can i tell if i have long or short injectors, do i have to pull them? Correct me if im wront but arent the later 6.2 and 6.5 injectors the same thread pitch? I remember reading about course and fine thread pitch but not long and short type.
