- 1,959
- 222
- 63
- Arizona
Contained herein are some photos of a M275A2 2-1/2 ton deuce tractor pulling a M313 6 ton expando van trailer that was involved in a collision. The trailer was heavily loaded with radio equipment. A civilian tractor trailer rear ended this combination probably going considerably faster than it was. The M275 was probably not traveling fast enough and was not well lit enough for the conditions it was in. The accident happened late at night in the dark.
The trailer's suspension is broken and disconnected from the frame. The kingpin is broken off in the fifth wheel, which is mangled. The trailer hit the cab of the truck after the kingpin broke and fell on its passenger side. Apparently the tractor spun around completely and the trailer struck the tractor again on the front. There is a spare axle hanging from the winch of the tractor.
The M275 driver was killed and the other driver was hurt as well. I won't say who this was or where it was out of respect to the person's friends and family. What is to be taken away from this is that thought should be given as to your route, time of travel, and sustainable speed that you can travel at.
