- 2,037
- 221
- 63
- North West Arkansas
My 86' M1008 has had a mild death wobble for a while, changed four set of tires still wobbles. So I replace the steering dampener and the king pin springs and bushings, very easy replacement! However this has only reduced the wobble by maybe 95%. You can still feel the slight bump of the wobble still there, very mild but still there. I noticed when I replace the spring and bushing on the driver side (the wobbling side) I had to use a jack stand to keep the hub level as I replaced the spring and bushing or the hub would droop and bump the bushing out of alignment. The passenger side did not do this? Is this a sign the kingpin is bad?
