nb102
- 0
- 1
- Southern Illinois
I'm finally getting around to start restoring my 62 Studebaker M35A1. But after buying a replacement intake duct for it and finding it doesn't fit my turbo, I'm trying to find out for sure which engine I have. I have do quite a bit of searching but haven't been able to really figure this out.
From what I've found:
Are there any other markings on the block that will give me an idea of which engine I actually have? I searched the numbers I saw but came up with no results. Any other visual differences between the blocks?
Maybe I just have a Frankenstein engine...
Also, anyone know where I can get an intake duct that will fit the 5 ton turbo? I've got a NOS m35a2 intake to trade...
Any help would be much appreciated.
- There is no id tag on the engine that I have seen
- My truck should have started life with the LDS-427
- The top of the engine does not have the funnel oil filler
- The turbo is a Schwitzer 4-456 (for a LDS-465-1? http://www.steelsoldiers.com/showthread.php?61801-Turbo-part-number-ID)
- The injection pump is a HD90101A (also for a LDS-465?)
- The air compressor is a two cylinder version
- The voltage regulator says 25 amps, 28 volts
