cooling system mod
orrisd4
10
HoneyGrove Pa
Im still working on getting all the hoses on my a2 repaired .This seems like a good time to ask this ,
can a coolant filter be used with a fuel fired coolant heater ? Also has anyone managed to hookup a recovery bottle to an a2 if so please point me to it .(yes i have looked , nothing is coming up)
goldneagle
1,014
Slidell, LA
If you put a T in line of the heater hoses you should be fine. Check out my thread on M923 to see how i did mine. I have separate shut-off valves for the filter and the heater.
orrisd4
10
HoneyGrove Pa
yes , we have always called em recovery bottles, same thing just a different name , also eagle i was planning to do away with the water heater altogether and run an arctic fuel burner ,
goldneagle
1,014
Slidell, LA
Then just use the existing lines to the coolant bypass filter and call it a day. Good prices for the setup on AMAZON.com.
