asstor
- 0
- 0
- Austin, TX
Hi guys.
I am doing a complete nuts and bolts restoration of an early 1951 M37. You can check out my progress at www.m37rebuild.com.
I have run in to a problem with the transfer case rebuild I can use some advise on. Upon stripping the xfer case I discovere that the input shaft from the transmission has pretty sever damage to the roller bearing journal. It has develeop a condition known (as I have learned) called brinelling. It is caused by excessive vibration on the bearing. As the bearing is locked by the HI/LOW dog clutch when the xfer case is in high range, the needle rollers eventually create long dimples in the bearing journal. Check out the picture below.
Getting a replacement shaft is near impossible. I eventually found a NOS shaft from one of the usuall suppliers. Unfortunately it is even in worse shape from sitting on the shelf for 60 years.
The question is, which one of the two do you recommend I use? Which is the better of the two evils?
I have though of a third possible solution. I have a lathe with a tool post grinder, so I can machine and re-grind the journal and then replace the needle bearing with a sold bronze bearing that I can machine to the correct clearances.
I know the journal can also be repaired by metal spraying and the re-grinding, but I believe that is not a good solution for needle bearings and the cost may be prohibitive.
Any thoughts?
Thanks to all.
Louis Barkhuizen
Any thoughts?
Thanks to all.
Louis Barkhuizen
