Replacement leaf springs for M101A1
Recovry4x4
LLM/Member 785
1,808
GA Mountains
How far are you from Hesperia? Walker Automotive would be worth a call. They have tons of goodies.
dstock
SoCal
Found a pair of used springs on the east coast. Much cheaper than new for the time being.
Now, does anyone have the measurements on the axle u-bolts? I had to cut all of mine off right at the bend, I know they are 6 3/4" long x 1/2 bolt diameter, but don't have a full one to measure the width across the inside of the u-bolt. At the very top it appears to be 2"?
Thanks for the help!
rosco
30
Delta Junction, Alaska
I don't know the measurement, offhand. But usually an RV Trailer supply house has generic ones - 2x1/2" being common. They will be extra long, & meant to be cut to length by the end user. Be sure to use "neverseize" & I like to cut them pretty short after the nut, as they get abuse from rocks - then there is a hope that they will un-screw later.
doghead
4 Star General /Moderator
1,177
Post#8 told him about the classifieds.
He must not want those parts(for some reason).
dstock
SoCal
dstock
SoCal
Been talking with Piper Cub regarding the one in the classifieds, he only has one available as I mentioned in Post #10. Found a pair on the East Coast and the pictures look the same "rust wise" as the one in the classified so I went with the pair versus one from one place and one from another.
