My M925 has had the same hard downshift since purchase, this is good info and I'll check the condition of the modulator feedback cable.I went through this exact issue with my 925A2 this past weekend. WildChild467 and I went to the local mud bogs, and after, I had an extremely harsh 2-1 downshift that was not there earlier. The trans shifted gravy smooth before through all 5 up and down. Occurred at about 7mph on the downswing to a stop. Thought it was the torque converter not wanting to unlock, but it would do it in neutral also while rolling up to a stop.
Check your modulator cable at the injection pump linkage. Make sure it is free to move the entire length of the oval slot in the throttle lever. For my issue, I found that the modulator cable was not self returning to its home position 100%, as I could manually push it back further. I pulled the seal back on the cable, and sprayed WD-40 down the cable housing as best as I could, while pulling the cable core out and letting it snap back to seated position about 20 times.
Took the truck for a ride, and the harsh 2-1 downshift was gone. I'm not so sure it is "nature of the beast" as others say (I buy stuff from Suprman, so no offense there), at least for me it was more of a factor of the modulator cable being 24 years old. It should be spring loaded on the trans end under the cover where the cable terminates. This cover has tamper-proof 3 slotted screws, but start with lubing the cable and checking its travel on the return stroke. Also if it is shifting early and bogging the engine down, move the adjustment to max position at the injection pump end. Mine was set that way and the shift points seem great. I can force a downshift by mashing the pedal, etc.....
If you modulator cable is adjusted best it can be, the spring return is working on it, and it is lubed and can return to its fully seated position, then yes it may be nature of your beast.
That hard 2 to 1 downshift is not as hard on the human driving the vehicle as it is for the universal joints and gearing in the differentials. It is also tough on the transfer case. When sizing a gear reducer for an industrial application, one must use a much larger service factor-or gear box when there is shock loading at a given horsepower. Bottom line-shock loading mechanical stuff will reduce its life.Do yourself a HUGE favor.
Get a medium towbar and tow another 5ton for about 100 miles. Up and down
and flat and forward and even some reverse.
Thise trannys are made to HAUL HEAVY HEAVY LOADS, they are not cushie
civilian nice trannys! THEY are MONSTERS and trying to tame them is real hard
BUTSOMEHOWEVER. That "edge" is now gone from my tranny after I towed 7
other like trucks for about 140 or so miles. These are TACHTICAL MILITARY TRUCKS
not 1/2 ton chevys...
Been there, done that.
Now add 10 Ton and tell me all about it...with all due respect indeed sir.That hard 2 to 1 downshift is not as hard on the human driving the vehicle as it is for the universal joints and gearing in the differentials. It is also tough on the transfer case. When sizing a gear reducer for an industrial application, one must use a much larger service factor-or gear box when there is shock loading at a given horsepower. Bottom line-shock loading mechanical stuff will reduce its life.
Pete
