rustystud
- 2,987
- Woodinville, Washington
Quadjeeper, you are really going that extra mile ! I like it !!!! I totally agree with "Ahab" . Do it right the first time and there won't be a next time !
I'd like to be able to get one of these, but their website says for gov. contract or law enforcement only.
That kind of hoakum is frustrating:I'd like to be able to get one of these, but their website says for gov. contract or law enforcement only.
Maybe start your own Law Enforcement agency:Don't know anyone in Law Enforcement? Time to make some friends!
I hear you:That sounds complicated for getting a generator - I guess I just like having friends
Good point, sleepercab; I didn't think about that. But I sure wanted one bad.I traded for a Mossberg 500 12ga. with 16" short barrel and adjustable stock. With high brass 23/4 shells it kills at both ends being so light. It kicked like a bank mule and sheared off the shell holder plastic rivets . An AR butt stock cushion and a shotgun rubber cushion now occupy the killing stock. I intend to load some varmint mixed shot with medium power for in home target practice. I say shoot one before you buy one. (I still own mine)
Go for it, no patent.I am going to copy this.
Now THAT is thinking ahead; brilliant:Ok, finally got the back door dead bolt lock squared away. Added a reinforcement plate to the inside of the door, the inner door panel sheet metal is quite thin. Considered using carriage bolts through the door for better security, but I like the clean look on the outside. Wanted to mount the lock above the handle for when I add the rear deck, but is a long reach from the ground. Maybe someday, after deck/porch is in place. Also cut off the padlock tang from the outside handle so someone cannot lock me in.
Hey, I'm planning on going to the Georgia Rally next year, some of those guys might want to lock me in!
True that Frank. I have off two weeks at the end of the year. Planning on overhauling the master and two airpacks you sold me so I can get the dual circuit system installed.main thing is the brakes
