540fordman
- 0
- 1
- pana, il
Have the same issues on mine....although my races and bearings are entirely unusable. Gonna try and mod it to use a needle thrust bearing instead. I'll post pics when I'm done.
With the level wind you are adding another potential friction point going over the roller. How much harder is an interesting point that would be hard to quantify. Pulling out the cable I have found is always hard work and works easiest by running the cable out under power and keeping the cable tight by walking it out. The bad part is it is a 2 man operation. That said if you can get the cable out by hand without the level wind, if your level wind is working properly you could still get the cable out. You might be exhausted at the end of the pull but it would not be impossible.I hope this is the right place to post this question.... After a level wind is properly greased up and working properly, how much harder is it for one man to pay out cable by hand vs. not having a level wind? It is a lot harder? For example: If somebody was stuck and had to pull out 180' of winch cable, could one guy do it with a level wind on his winch? I pulled out about 180' of winch cable on a 925 the other day and it was work, but i was also in slippery mud and it IS 5/8" cable. So if the truck had a level wind would it be a whole bunch harder to pull the cable out if the level wind is properly lubricated and everything else adjusted properly?
Appreciate that - I just threw that in as it had been previously discussed and the principle is the same - just in the opposite direction (if the front has a level wind).I am referring to a front winch with level wind.
Not necessarily in order - but here is a start for you to consider...I would like to see peoples opinion what they prefer in this situation…. Level wind or no level wind. Thank you![]()
i know its an old thread, but its been useful for me and hopefully for others in the future. as for your query, the past couple days iv been messing with my set up and yes, it was work and breath taking for a fat young, but old fart like me, but i was able to manually pull al the cable off by hand. as mentioned, the level wind adds a bit more drag, but it is manageable. pull till your dragging cable on the ground and get winded, then walk closer to the winch, grab more cable and drag it as far as you made it the first time. rinse and repeat till you have enough cable to reach your target vehicle.I hope this is the right place to post this question.... After a level wind is properly greased up and working properly, how much harder is it for one man to pay out cable by hand vs. not having a level wind? It is a lot harder? For example: If somebody was stuck and had to pull out 180' of winch cable, could one guy do it with a level wind on his winch? I pulled out about 180' of winch cable on a 925 the other day and it was work, but i was also in slippery mud and it IS 5/8" cable. So if the truck had a level wind would it be a whole bunch harder to pull the cable out if the level wind is properly lubricated and everything else adjusted properly?
I love the look of a level-wind. I bought one and added it. Then, I absolutely hated how much more difficult it made it to free-spool out the cable. When I am stuck, it is going to be in 4’ of yuck, and that is not when I want even more of a physical challenge. I then removed and sold it due to that.i know its an old thread, but its been useful for me and hopefully for others in the future. as for your query, the past couple days iv been messing with my set up and yes, it was work and breath taking for a fat young, but old fart like me, but i was able to manually pull al the cable off by hand. as mentioned, the level wind adds a bit more drag, but it is manageable. pull till your dragging cable on the ground and get winded, then walk closer to the winch, grab more cable and drag it as far as you made it the first time. rinse and repeat till you have enough cable to reach your target vehicle.
what i wish they would have put on these was a type of manual brake to use when pulling cable by hand to help keep the cable from rats nesting.
i guess v got plenty of weight to put behind the pull. i do agree though, i found it slightly more difficult, but nothing to to difficult, to pull compared to when the front didn't have the winder. i just grabbed a root and started pulling. i yarded about 50', dropped the cable, grabbed a new handful and repeated till i got all the cable off. i had 5 layers of cable on the ground in just a few minutes. pulling through mud, yea, it sucks, but its gonna suck no matter what. but to each our own. i wanted it for a 1 person operation, which i think it'll do just fine once i get another valve installed up front.You are bending a 5/8” diameter cable into a 180 degree U around a pulley. So even with everything loosened up, it is still a stiff chore, my opinion.
Oh, yeah, that is a pain in the neck for sure.what i wish they would have put on these was a type of manual brake to use when pulling cable by hand to help keep the cable from rats nesting.
