74M35A2
- 317
- 83
- Livonia, MI
Anybody done it? I see electric ones, but maybe I'm missing any hydro ones. I just picked up a second winch complete with brackets and frame extensions, clone of the front one I have, to add to the rear under the bed between the frame rails. Seems like a perfect fit with ample room behind the rear axle, just bolt and go (?). Looks like will need to notch the wood between the frame and the bed rail. Then plan to replace the cable actuated single hydraulic valve with two 24VDC solenoid types, one for each the front and rear. Maybe go air actuated PTO, and ditch the control tower completely. Finally water resistant momentary rocker switches both inside the cab and one at each bumper. I likely won't be using the frame extensions if I keep the rear cross member where it is. May lose the rear pintle gussets, oh well, don't use it much anyway.
This second winch had a level wind on it which I wanted also, so that will be going onto the front. Combined with the solenoid hydraulic valves, should make it reasonable to use by a single person (driver).
Stay tuned...
-74
Stay tuned...
-74
