wehring
- 26
- 38
- Angleton, TX
CAT tech just left and the LMTV now has an accurate speedo and a 330hp flash. When we changed the axle gears from 7.80 to 6.14 the speedo was off by 15mph.
Here is the info you need to give your CAT guy to correct ...
40291 pulses per mile
Found in vehicle speed cal in engine ECM configuration
hope this helps
justin wehring
979 997 3112
hope this helps
justin wehring
979 997 3112
