74M35A2
- 317
- 83
- Livonia, MI
Well you can't find out what it is capable of unless you push it. It was my first time using a winch and man was I glad that the truck had it.Found out what it took to get it stuck. Confirmed winch works. View attachment 523150
Good deal, now track your milage and engine time. Oil analysis in your next step. As long as you get good oil spec feedback readings, just change the filter and add a little oil. It will save you a lot on oil changes.Upgraded to a spin-on oil filter and changed the oil. Thanks for the adapter Scar59!
Sealed front windshields between glass and frame.
Replaced wood strips between bed and frame and replaced the bed bolts.
Replaced leaking heater hose valves.
Replaced passenger seat latches.
