Power steering for the Deuce?
Jeepsinker
396
Dry Creek, Louisiana
Steve, did you cut any length off of the arm before welding up the new boss area? It seems that you cut it shorter and then built the whole boss up with weld, is that correct? G, that is also some very nice craftsmanship on your piece.
steve6x6x6
37
Winter Haven, florida
The upper front mount bolt on the steering box lines right up on the rivet hole that was left behind from the reinforcement plate. It has that circle on it. This looks like the place to put it. This is the same as M35A2 and A3.
steve6x6x6
37
Cut the large hole in frame, cut and brake up the flange. Drill a lot holes and plug weld one hole to the frame. My tank is from a 2000 up F650/ F750 power steering reservoir, i cut and welded in a section to double the capacity. The next couple of days I have a lot parts to make, machine from billet.
