- 14,601
- 4,672
- Buchanan, GA
Rest assured, he's got more than a pin hole casting flaw.But for all we know it could be a pin hole casting flaw. He really has nothing to lose. I don't expect it to work. but I would try if it was my truck.
Probably doesn't have anything to loose, I did it in mine before tearing to down. But I very much doubt it will solve anything at all.Looks like I am going to be looking for a motor. Pressurizing the coolant with 10lbs overnight yielded no coolant in the combustion chambers. What I did observe, was that it only loses pressure when the engine is hot. Once it cooled off, it stabalized at 5 lbs overnight.
In the morning, I cracked the drain plug and another couple cups of antifreeze came out of my fresh oil change.
I will probably not do anything until spring, and ill drive it in the meantime as is locally. It has to be a cracked block, that is my best guess after running these tests and looking it over.
