M931A2 Cummins basic info request
dabtl
Denton, Texas
So, I either have 18 quarts or 22 quarts oil capacity. I see the M939A1 has 22 and the M939A2 has 18 quarts. My M931A2 then would require 18 quarts? Still confusing but I will catch on. I promise.
doghead
4 Star General /Moderator
1,172
A1, 14 liter
A2, 8.3 liter
Engine displacement.
doghead
1,172
You should have a data tag on your dash.
It tells you the oil capacity, and TM numbers to use.
Same as most military trucks.
73m819
319
gainesville, ga.
It sorta HELPS to READ the TMs that covers the trucks you own, there is a LOT of tid bits of interesting info in them, like HOW MUCH OIL to put in at a oil change, because if MORE oil is drained then what goes in at the oil change just might indicate a slight problem.
dabtl
Denton, Texas
To be perfectly honest, I have yet to drive the tractor. I got it a couple of years ago in trade and it has mostly sat or been driven in parades by friends. So, I have yet to see the data tag!
It may get some use pulling an M113 around, but that will be later this Spring.
