"Loud" Turn Indicator
Another Ahab
4,579
Alexandria, VA
Can't find it to save my hide:
- Searched "Loud"+"Turn Indicator"+"Turn Indicators" (because search engines got their limitations)
- And scrolled through 7 pages of Threads, but no readily evident "hit"
- Pretty sure I read this detail once here in some thread somewhere
Anybody maybe recall what thread mentioned a purchase source for those UPS-style super loud (idiot proof) audible clickers for turn signals?
tim292stro
41
S.F. Bay Area/California
If you can't find it, wire in a 24V beeper and put it in your dash facing you. Positive lead with a 1-amp ATO fuse to the H-pin coming out of the turn signal switch, negative to ground. Beeps with the turn signal flash, and like the model I linked you can adjust the volume :).
jatonka
87
Ephratah, New York
Search for Cranetruck posts back about 7 or 8 years ago. He developed the first loud turn signal flasher for deuces using the low air buzzer. Doghead might remember the thread title
Another Ahab
4,579
Alexandria, VA
Thanks, John; I'm actually all good with Tim's response above (just what the doctor ordered):
- Everything is there for me to do what I want to do
But thanks for your suggestion, too!
m16ty
218
Dickson,TN
It would help if we knew what vehicle we are talking about. While most M series vehicles use the same turn signal indicator, some MVs like the CUCV does not.
tim292stro
41
I'm wary of mixing systems and adding meanings to warning sounders - wouldn't want to think I had my turn signal on when my air was low, and wouldn't want a turn signal mod to potentially risk the low-air warning from not working... :2cents:
Perhaps presumptuous of me but I saw the M35 in his signature and connected the dots. :beer:
The TMG version only works if you have the turn signal switch with the light in it, I also recall a few complaints in that thread with volume if the installer didn't drill a hole in the lens. This mod works with any M-series turn signal switch/flasher version. For CUCV the principal for this method is the same, tap the flashed output of the flasher - which only runs when there is a load selected and the flasher is powered. Cheap parts and common availability make this a simple mod, that's easy to repair.
Assuming your MVLS shuts off the turn signal functionality, it will also auto-mute when in blackout mode, if not there is a simple way around that with one more cheap/common part.
Another Ahab
4,579
Alexandria, VA
i bought my blinker buzzer from
those military guys
its really loud
"Blinker Buzzer"; now that's a perfect two-word description for it (I couldn't come up with a description that good myself).
And the comments here are all of them helpful (think you to all), but the application is not for an MV at all, but instead for a conventional commercial vehicle. I was just looking for the device:
- I hate catching myself leaving my own blinkers on.
cranetruck
77
Meadows of Dan, Virginia
Simple mod really, and won't be mistaken for the low air warning, which is uninterrupted.
