flyingfrog509
- 0
- 0
- Calhoun,GA
Have had my M1009 for a few years, it mostly sits because other stuff keeps coming up. IT IS TIME to get that baby rolling.
I had tagged onto the end of an old thread back in 2010 about replacing the head gaskets because that is what I was told that was the problem. Since then I've also been told that typically raw fuel smell is from the injectors needing to be rebuilt/replaced AND to try that first before pulling off the heads. All of this while trying to find a shop that works on 6.2s in my area...no one works on them around me that I can find. I'm not convinced it is the head gasket yet (not that I know what I'm talking about) because I've not had water in the oil and I found a small leak in my radiator hiding under the neck that explains the water loss I've seen.
With that said, I'm competent...just got done rebuilding a 350 vortec and slapping it in my wife's beloved suburban. Just trying to get advise on how to attack getting the M1009 back on the road and with confidence with out breaking the bank.
I saw the thread saying the bosh injector nozzle(s) #0434250105 can be had for under 10 bucks each, so for 100 bucks that seems like a cheap place to start and something that isn't a bad thing to do regardless.
NOW THE REAL QUESTIONS:
1) Does rebuilding the injectors seem like the most logical place to start?
2) How do you know if the harmonic balancer needs to be replaced? (OR JUST DO IT for 100 bucks and be safe)
3) If I have to pull the heads, is it critical to buy a stud kit or are new bolts good enough? (if stud kit does someone have part numbers)
4) Are there other things that are just given to do before driving it a lot?
My M1009 seems to be totally stock. Still has 2 batteries & 2 alternators so I'm guessing 24/12 volt set up. AND if you all want a laugh once I was out fishing with my son and my knee hit the black out switch...you can imagine my surprise when the lights didn't turn on at sunset to get home! Took me hours to figure that out after we got home. So simple...if you know its there and what it means.
Thanks for any feed back guys.
