I was thinking more along the lines of a Gm turbo,3 inch down pipe and 4 inch exhaust,with maybe a 5inch big fart exhaust tipAnd a big fart can exhaust tip?
I'm a stubborn one though. I have to try and fail before I farm out the work.That is awesome!
I would consider myself a seasoned mechanic and not afraid to tear into an auto trans or do internal engine work. I personally would farm out my IP work to a Stanadyne dealer. Its one of those things where it pays to just let the expert do the work. I've R+R'd mine and even pulled the top cover plate off to adjust the fuel screw. Anything further than that I would recommend someone that does it professionally just for peace of mind. Just my two cents.
I started getting a knocking sound from the bell housing area. The cone broke off and is bouncing around in there....and the bolt hole towards the center of the vehicle, there is a big ol crack coming from it going diagonal across the body of the starter. It is about 2 inches long.In half? Like right through the center(steel housing)?
If just the nose cone broke, that is replaceable and that is the best option.
It is OEM. The guy is matching Amazons price for me.If AZ has the for that price and they are OEM (24 volt), I'd like to get a few of them.
See aboveProbibly not Delco-Remy at that price. Trust but verify.
The body of the starter has a giant crack coming from one of the two bolt holesGet a new nosecone and fix your own.
Be sure to install the thrust washer on the shaft.
All parts are listed in the parts TMs.
No, 'tis not so deep as a well, nor so wide as a church-door; but 'tis enough,'twill serve. Methinks your starter is toast!The body of the starter has a giant crack coming from one of the two bolt holes
